Activity › Forums › Avid Media Composer › Avid – Nuendo workflow
Posted by Eric Sharon on July 4, 2005 at 6:38 pmHas anyone managed to work out a successful workflow between Avid Xpress Pro 4.6 and Nuendo 3?
Eric.Dirtyho replied 21 years, 1 month ago 3 Members · 3 Replies -
Wes Plate
July 7, 2005 at 9:31 pmOther than export OMF with embedded audio out of the Avid and then import that into Nuendo?
— Wes Plate
Automatic Duck -
Eric Sharon
July 9, 2005 at 5:02 pmWes, thank you for your reply. The problem is to export the audio back to Avid. I’ve tried OMF, but it just doesn’t work.
Eric. -
Dirtyho
July 29, 2005 at 1:09 pmI’ve experienced problems passing OMF from Avid to Nuendo. Nuendo would open the OMF but some (not many) of the clips in the timeline contained the wrong media. The sound designer I was working with solved it by opening the OMF in Pro-Tools and re-exporting it. You might find a workaround like this. HTH
