Activity › Forums › Avid Media Composer › AVID not bring in PSD the way it should
  • AVID not bring in PSD the way it should
    Posted by Editproblems on September 17, 2006 at 12:14 am
    Hey,
    I am trying to import a .psd file of a gradient rectangle (used as a title bar) into AVID. When imported it comes into AVID as a Matte Key and i can crop it all fine but instaed of being transparent at one end (as it is in photoshop) it comes into avid as a white background so once i crop it one end is white instead of transparent. Can you guys please help me!!!???
    Editproblems replied 20 years ago 4 Members · 4 Replies
  • Alex Alexzander
    September 17, 2006 at 2:02 am
    When you have selected Import, Choose Options, and then under the Alpha section, choose Invert Existing.
  • Grinner Hester
    September 17, 2006 at 7:51 pm
    you may also wanna try saving png files from photoshop.
    You can keep PS drop shadows, bevels ect that way.
  • Michael Hancock
    September 18, 2006 at 8:50 pm
    If you made a black to white gradient in photoshop it will import as a black to white gradient in Avid–if you created a solid to transparent in Photoshop do as Grinner said–save it as a .png on a transparent background–the transparency in photoshop will be saved as your Alpha channel. Import it “Invert Existing Alpha” into Avid just like the others have suggested.
    If you just have a black to white gradient you want to use as a matte then import it with “Ignore existing Alpha” checked and apply a matte key effect to it, or a luma key. This will use the black and white and shades of grey as data for your transparency, giving you the result I believe you so desire.
    Mike.
  • Editproblems
    September 18, 2006 at 9:08 pm
    Sweet…..it works great!
    Thank you guys so much!!!!!!!!!
