Activity › Forums › Apple Final Cut Pro Legacy › Avid MXF files in FCP2
Posted by Dan Nethery on January 31, 2008 at 2:25 pmDoes anyone know how to get avid MXF files to work in FCP2?
Thanx, dan…
Bjoern Adamski replied 17 years, 4 months ago 7 Members · 9 Replies -
Dave Schweitzer
January 31, 2008 at 11:10 pmHave you tried installing the latest Avid codecs? (then relaunching FCS)
Santiago Gutierrez
February 1, 2008 at 12:40 amIf you want to edit in FCP6 with AVID media that you digitized in .mxf format, you’ll have to use Automatic Duck’s FCP Pro Import to “see” the mxf media. Pro Import creates Quicktime wrapper files for the AVID .mxf files because FCP cannot read these on its own. You’ll be able to see your footage inside of FCP. Be aware of the limitations of this: You will not be able to edit to tape or output your sequence unless you render the whole timeline in the appropriate compressor that goes with your capture card. If you have a Kona 3 for example, you’ll need to work in a time line that is Pro Res, Uncompressed, or using another codec that is supported by your capture card for output.
Most people prefer to “recapture” the footage inside FCP to an appropriate codec that they will not have to render for regular playback. Automatic Duck will allow you to do this by taking the AVID sequence and converting it into a FCP sequence. -
Audun Hopland
February 14, 2008 at 2:15 pmhi,
Keep an eye up for mxf4mac.com. I think the will release something quite soon. -
Bjoern Adamski
December 20, 2008 at 10:13 am -
Andy Mees
December 20, 2008 at 11:28 amIf a job’s worth doing its worth doing well, Bjoern.
Congrats on the new release.Best
Andy -
Dan Johnson
April 4, 2009 at 3:52 pmSo which is better. MXF4mac or Automatic Duck? They both seem to be very close in price.
Bjoern Adamski
April 4, 2009 at 5:42 pmWe don’t compete. Automatic Duck focuses on project exchange, we focus on MXF media exchange and we cooperate to provide an even better integration in the future.
Product Manager
MXF4mac
https://mxf4mac.com -
Dan Johnson
May 16, 2009 at 4:02 pmSo Automatic Duck doesn’t let you work with the MXF clips in a FCP timeline?
Bjoern Adamski
May 17, 2009 at 8:17 amDepending the compression format AD provides QuickTime Reference Movie files that point to the native MXF.
Product Manager
MXF4mac
https://mxf4mac.com
