Activity › Forums › Avid Media Composer › AVID MOJO SDI
AVID MOJO SDI
Posted by Jk Video on May 12, 2007 at 2:33 amI have a quick question as we are researching going from the original MOJO to the SDI version.
#1 is the component output better on the SDI version? As has been discussed on this board before…the component output on the original MOJO left something to be desired.
#2 can you get SDI and Component output at the same time from the MOJO with SDI?
Thank you in advance.
Oakmozart replied 19 years, 4 months ago 4 Members · 3 Replies -
Bouke Vahl
May 12, 2007 at 3:34 amdunno if it’s better, but you got SDI and either composit or component at the same time…
Bouke
http://www.videoToolShed.com
smart tools for video pro’s -
Milton Hockman
May 12, 2007 at 5:37 pmi just got SDI mojo. I love it! I hated the earlier mojo because i could only do component and when i used the firewire to get 1:1 from XD Deck it was not as clean as i thought it would be. SDI mojo is a great upgrade!
but yea, the mojo allows In/Out Composite, Component, S-Video, and SDI. I have my SDI hooked up to my Digital S deck and my Component hooked up to my Beta Deck.
You have to make a choice when inputting or outputting everything but SDI. Because the component, s-video, and composite all use the same cables. You can use all three RGB connectors for component, Blue only for composite, or Blue and Green (or red.. i forget) with a supplied connector that feeds to an s-video connector.
I imagine taht if you set your output digital cut to RGB component you could record to a deck at the same time with the SDI hooked to another deck. I think the SDI alwayws outputs a signal no matter what. So in theory you could do both at the same time, but you would be doing a slam edit on the SDI while the component can have accurate timecode.
The only pitfall to the SDI Mojo is that it only has 1 SDI output cable. Therefore you cannot output SDI at the same time as monitoring SDI on your tv monitor. Only way you can do that is if your tv monitor has an SDI loop through. Otherwise you have to monitor Composite while outputting SDI. Or you could just keep moving the SDI cable from your monitor to your deck when it is time to output.
My tv monitor has an SDI loop through which solved this problem. I took the SDI out cable from Mojo and ran to my tv monitor input and then the output SDI on the monitor to my deck.
hope this helps.
Oakmozart
May 13, 2007 at 3:32 amMy sentiments follow the above. While Mojo SDI has several pitfalls, the one that bothers me most is that it’s SD-only. If it were HD-capable, I’d SLEEP with the dang thing!
If you need SDI i/o and you’re working with XPro or MC-soft, then don’t even hesitate: shell out the $2600 and buy it! (Keep in mind you can get it for cheaper than the $2600 MSRP Avid slapped on it last year. Your dealer should have some wiggle room, and you’d be amazed at the deals you can find on Ebay. I wouldn’t buy one used, though.)
My opinion. Take care.
