Activity › Forums › Avid Media Composer › Avid Mojo audio playback difficulty
  • Avid Mojo audio playback difficulty
    Posted by Thegame2737 on January 26, 2007 at 11:00 pm
    Hi guys,
    I was wondering if anyone has had any difficulties with their Avid audio. Now, its not a problem when i export it, but I have a mojo, and playback out of the mojo sounds like its skipping and there’s an echo to it. I have minimized it but its still there and i Wonder if it could be bc of the fact that I moved my computer, thus had to unplug mojo and now need to do something to it in order to make it work correctly again, or if there is something else- if anyone has any idea y this would be happening i’d really appreciate your help.
    Sincerely,
    John
    Thegame2737 replied 19 years, 7 months ago 1 Member · 1 Reply
  • Thegame2737
    January 29, 2007 at 4:29 am
    Just so you know, if anyone else has this problem i did figure it out, kinda. While the audio still has the echoey noise while coming out of the mojo, if you look on the top of your timeline and more towards the left you’ll see a small square button that says “DNA” when i pressed it it then read “1394” – returning it to the “DNA” setting reduced the noise, but when i turned my actual computer speakers on i realized when in “1394” mode the audio came out of my normal computer speakers and perfectly normal. I dont know why it works, maybe bc the audio output is changed to the firewire out of the mojo and into the CPU when i put that setting on? oh well i dont know and i dont care it works haha.
