Activity Forums Apple Final Cut Pro Legacy Avid Meridien Codec & FCS2
  • Avid Meridien Codec & FCS2
    Posted by Adam Smith on September 9, 2007 at 5:13 am
    I coulda swore I read about this just a day or two ago, but I can’t find the thread anywhere…
    I’m running FCS2 at home, Avid Meridien at work. I’d like to be able to bring movies home for reference, create new elements, and then take them back to work.
    The problem is, I can’t get the Avid Meridien codecs to work with quicktime here at home. I did find mention on an Apple forum that the Meridien codecs were possibly not mac-intel compatible… has anyone had any luck getting these codecs to work?
    I’m running a MacPro 8-core, FCS 2, QT 7.2.0
    One proposed solution is to set Quicktime to run in Rosetta mode… not sure how to do that yet, but I’d prefer to know if FCS will have any issues with it before I try it…
    Video Photographer / Avid Editor / Final Cut Neophyte
    Philip Eoute replied 16 years, 4 months ago 4 Members · 6 Replies
  • John Pale
    September 9, 2007 at 1:15 pm
    Install the latest version of Avid Codecs available here.
    This package supports the long discontinued Meridien hardware as well as current systems. It also supports both PowerPC and Intel Macs.
    https://www.avid.com/onlineSupport/browse.asp?productID=0&topicID=404&browse=
    No need for Rosetta.
  • Adam Smith
    September 9, 2007 at 5:30 pm
    I’m awful sure that’s the version I tried yesterday with the same lack of success as my previous attempts, but I could be wrong… I’ll redownload and try it again when I get home.
  • John Pale
    September 9, 2007 at 5:48 pm
    Try this instead. The Avid site has this stuff poorly labeled.
    These is definitely Intel compatible.
    https://www.avid.com/content/3555/MacIntel_AvidCodecsLE.pkg.zip
  • Adam Smith
    September 10, 2007 at 4:02 am
    [John Pale] “Try this instead. The Avid site has this stuff poorly labeled.”
    You’re not kidding… the last 3 times I checked I found the same codecs that didn’t work (even though they were listed as MacIntel compatible), but the installer you linked worked like a charm.
    Thanks much!
  • Lorenzo D q
    October 27, 2007 at 1:17 pm
    I tried that link and got this:
    Page Not Found
    The file or page that you are looking for cannot be found or has been moved. Please choose from one of the links below or use our search engine to locate the information you are looking for.
    * Avid Homepage
    * Knowledge Base
    * Sitemap
    So, has anybody found a reliable link to intel compatible avid codecs?
    ‘been searchin’ for days!
    thanks
  • Philip Eoute
    April 30, 2010 at 6:50 pm
    I know this thread is three years old, but I ran into the same problem today and found this link, which helped:
    https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=263545
