Activity Forums Apple Final Cut Pro Legacy Avid Meridian QT Codec In FCP5
  • Avid Meridian QT Codec In FCP5
    Posted by Mickavid on March 12, 2006 at 5:52 pm
    I have been given some AVID MERIDIAN QT video clips. I would like to play them in FCP5. Is there a workaround? Or am I forced to use them in Avid?
    I looked for a FCP Avid Meridian codec but found nothing but posts that were asking the same thing.
    thanks,
    Mick
    Mickavid replied 20 years, 5 months ago 3 Members · 4 Replies
  • Simon Webb
    March 12, 2006 at 8:22 pm
    I believe that if you download the Avid Meridien Codec for OS X, it should work with FCP.
    https://www.avid.com/onlinesupport/supportcontent.asp?productID=10&contentID=3555&typeID=
    Hope this helps.
  • Mickavid
    March 12, 2006 at 11:36 pm
    Perfection!! thanks…
  • Andy Mees
    March 13, 2006 at 12:11 am
    as far as I know the Avid Meridian codecs that are available for direct download from Avid support are not OSX10.4 compatible.
    one way to get Tiger compatible versions tho’, is to register for and download the free Avid FreeDV installer (from Avid’s website) … you don’t actually need to install the app, you just need to extract and install the quicktime components from the installers package:
    right-click on the .pkg file and choose “Show Package Contents”
    then double-click the Content>Archive.pax.qz file, which will un-archive first to an “Archive.pax” file and then to an “Archive” folder
    inside Archive>Library>QuickTime are the codec components –
    AvidAVDJCodec.component
    AvidAVUICodec.component
    and also, if you want it, the AvidAVdvCodec.component (which is Avid’s DV codec)
    drop these into your root Library>QuickTime folder then trash Archive.pax.gz, Archive.pax and the Archive folder
    cheers
    Andy
  • Mickavid
    March 14, 2006 at 8:15 pm
    Brilliant!! Worked fine. Looks better than the other codec by a mile.
