Activity Forums Apple Final Cut Pro Legacy Avid meridian codec Not Working
  • Avid meridian codec Not Working
    Posted by Mervyn on December 8, 2005 at 4:10 am
    Guys, Need help here again.
    I’ve tried the avid dv meridian codec. But it say general error. May i know what seems to be the problem.
    Really need to get this codec working. I am trying to export quicktime to protools so that the movie file can work in protools through a avid mojo.
    But everytime i set the settings, avid dv meridian, Least quality, 20:1 interlaced, millions of colors +, and when i click save there will be a general error that appears. SO need to know what is the problem. I downloaded it from a mac os version. And just place it in the library, quicktime. But it jus doesn’t work…
    Please advise…
    Mervyn
    Andy Mees replied 20 years, 9 months ago 4 Members · 4 Replies
  • Tony
    December 8, 2005 at 4:23 am
    Are you trying to use the Avid codec within an FCP sequence or did you post this question in the wrong forum?
    If not well I guess you did not know that Avid’s codec will not work in FCP as far as editing on an FCP sequence is concerned.
    Tony Salgado
    Tony Salgado
  • Mervyn
    December 8, 2005 at 8:08 am
    Ok what i means is compressing it to avid dv quicktime format….
    And no i am not in the wrong forum. Am using fCP but need to convert it to avid quicktime….
  • Rich Rubasch
    December 8, 2005 at 2:41 pm
    You keep saying Avid DV format, or is it the Meridien codec? Is your sequence 720 x 486? If so, you cannot directly create an Avid DV clip since that is 720 x 480. You will get an error on export.
    If your sequence is 720 x 480 and you are trying to make an Avid Meridien clip (486) you will also get an error.
    Rich Rubasch
    Tilt Media
  • Andy Mees
    December 8, 2005 at 2:59 pm
    check your other thread … you sound like you’ve mixed up your codecs
    export to AvidDV QT codec works fine with FCP, but their freely released Meridian codecs are broken in QT7 … you will need a recent release of Adrenaline or Xpress for QT7 compatible Meridian codecs
    cheers
    Andy
