Activity Forums Avid Media Composer Avid Media Composer v.3.0.5 start up error
  • Avid Media Composer v.3.0.5 start up error
    Posted by Steve York on November 14, 2008 at 8:47 pm
    We recently updated from Media Composer v3.0 to v3.0.5 on two systems. Both run on WinXP Pro SP2. One is a Mojo SDI system. One is software only. Now, on both systems, when we launch Media Composer, we see an error message:
    “An access violation has occurred. See error log:
    C:\Documents and Settings\All users\Documents\Avid Media Composer\AvidFatalErrorReports\Exception_2008.11.14_14.33.34.”
    The error report shows “Fault Module C:\Windows\System32\MSVCR71.dll”
    If we click OK in the error message window, Media Composer continues to load normally, and seems to function normally. Still, this may indicate some unseen problem, and I’d like to fix it. There is no mention on Avid’s knowledge base or forums. We tend to think it’s an Avid problem, because it occurs on two separate systems, both with and without Mojo SDI, and it occured on both immediately after we installed v3.0.5. Any information or suggestions will be appreciated.
    Steve York
    Steve York replied 17 years, 10 months ago 3 Members · 3 Replies
  • Michael Phillips
    November 15, 2008 at 4:40 am
    Did you do an uninstall first before the 3.0.5 upgrade? I would do that than reinstall and see what happens.
    Michael
    Michael Phillips
  • Terence Curren
    November 16, 2008 at 2:52 am
    Follow the install directions carefully. If you are upgrading from a 2.X version, there is stuff you have to uninstall manually before you start the new install. Also some registry editing.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Steve York
    November 17, 2008 at 6:39 pm
    Thanks for the suggestions, but as it happens we had already uninstalled all earlier versions and all the supporting files, per the release notes from Avid. We still have the problem
    Steve York
