Activity › Forums › Avid Media Composer › Avid Media Composer PC and XDCAM footage
  • Avid Media Composer PC and XDCAM footage
    Posted by Peter Vandall on September 8, 2010 at 1:06 am
    I am going to work on a project where I need to load, label and sync a two camera shoot into a rented Avid Media Composer. It is the PC version, and I assume the software will be version 5.
    The footage is tapeless XDCAM from two Sony EX-3 cameras.
    Can anyone tell me what the workflow is for this?
    Thank you!
    Peter
    Michael Phillips replied 16 years ago 3 Members · 4 Replies
  • Matt Mullen
    September 8, 2010 at 1:20 am
  • Michael Phillips
    September 8, 2010 at 8:43 pm
    Were they shot on the EX3 where you can jam sync them or is there common timecode between the two sources?
    Michael
    Michael Phillips
  • Peter Vandall
    September 8, 2010 at 8:45 pm
    I don’t know. What would the scenario be for both methods in post?
  • Michael Phillips
    September 8, 2010 at 11:31 pm
    If the cameras has common timecode and were jam synced, then grouping can be done via common timecode on the START column. If there is no common timecode, then you will need to find a common sync point, add a MARK IN on both clips then group based on MARKS.
    Michael
    Michael Phillips
