Activity › Forums › Avid Media Composer › Avid media composer 8.5 GoPro & C300 sync
Phillip Jacob replied 10 years, 3 months ago 3 Members · 34 Replies
Phillip Jacob
June 23, 2016 at 6:21 pmOkay.
So I just need to manually fix the points? But im not sure I understand why it leaves out 1 frame? -
Phillip Jacob
June 23, 2016 at 6:27 pmOkay.
So I just need to manuallyThe timecode is generated all day with a betso timecode, so it should be generating all day. ?
Michael Phillips
June 23, 2016 at 6:40 pmBecause the source clips as recorded are not continuous. The END timecode is MC is always +1, so in order for it be continuous in the recording, the END of the previous clip timecode must be the same as the START of the next one.
Michael
Phillip Jacob
June 23, 2016 at 6:52 pmOkay. A bit tricky.
I’ll just manually adjust the 1 frame difference.
Thank you Michael. Really appreciated!
