Activity Forums Avid Media Composer Avid MC7 AAF imported to Premiere CC
  • Avid MC7 AAF imported to Premiere CC
    Posted by Russell Anderson on August 13, 2013 at 11:14 pm
    tl;dr – Trying to export AAF from Avid MC7, and into Adobe Premiere CC using AMA’d footage, but sequences are blank.
    I’m well familiar with AAF’n things outta Avid and into either FCP, Premiere, or After Effects. I upgraded to Avid v7 and I use Creative Cloud.
    I have a sequence in Avid that contains AMA footage (relinked from my offline material). The source material that I’m AMAing to ProRes4444. Everything is relinked. I export with the right settings (I’ve tried with and without Edit Protocol, and the correct tracks are enabled). When I try to import the AAF into Premiere, it’s gives me an empty sequence with a trillion markers denoting that “[Generic] clip was dropped because no related footage was found.”
    I’ve been trying to resolve this for the last few hours, but with no success. I’ve tried it with tape names, with source file names, checked to make sure my AMA footage has a source path. I’ve tried it in After Effects as well, same results (unsurprisingly). I’ve also re-imported the AAF back into Avid successfully. So I know the AAF works on some level.
    My concern is that Avid monkeyed the AAF content around and it’s no longer compatible with some other applications.
    Has anyone tried this yet?
    August Anderson
    QRSlate QR-Code Film Slate
    • App: http://www.qrslate.com
    • https://vimeo.com/36621534
    Drigan Lee replied 10 years, 6 months ago 7 Members · 11 Replies
  • 11 Replies
  • Michael Phillips
    August 14, 2013 at 12:39 am
    I use AAF with Edit Protocol to reference camera originals (linked via AMA) in Resolve with no real issues. Do you get the same issues if you were to transcode to DNxHD on a small test to see if that works?
    Michael
  • Russell Anderson
    August 14, 2013 at 12:41 am
    Interesting, so the issue might be with Premiere’s interpretation.
    All DNX media was connecting fine. Just not AMA.
    August Anderson
  • Michael Phillips
    August 14, 2013 at 12:48 am
    As with an file format, it takes two to tango.
    Michael
  • Russell Anderson
    June 9, 2014 at 9:36 pm
    How embarrassing, this is still broken.
    August Anderson
  • David Scharf
    September 5, 2014 at 7:16 am
    Did you ever solve this? I’m using MC 8 (latest version) and Premiere (latest version) and having the same exact problem trying to bring an AMA-linked AAF (linked to Alexa ProRes) into Premiere. There were a few clips shot on C300 and those seem to carry over, but not the Alexa-based stuff.
  • Russell Anderson
    September 5, 2014 at 7:38 am
    wow, that was so incredibly random. I’ve been up all night trying to figure out a workaround to this problem. What a coincidence. I haven’t had to think about it in months.
    I was entertaining the idea of using Resolve as an intermediate. So
    Raw –> Resolve –> MXF –> Avid.
    then
    Avid –> Resolve –> New AAF –> Premiere.
    Haven’t tried it yet, though. Going to run more tests in the morning.
    August Anderson
  • David Scharf
    September 7, 2014 at 7:10 am
    any luck on this? Going out of my mind trying to work this out. A process that should be so simple is so confusing.
  • Jordan Wise
    November 21, 2014 at 9:42 pm
    I got it to work by exporting an AAF from Avid. Importing that AAF into Resolve. Exporting an XML from resolve and then importing that XML into premiere.
    Convoluted, yes. But the whole experience took less than 5 minuets.
    The only thing that didn’t relink for me was freeze frames. Title media linked, but came in bundled, one on top of the other as a nested sequence. Annoying, but easy to fix.
    If you have none of the above in your sequence, everything should link like clockwork.
    Hope this workflow works for you.
  • Viplav Nyshadam
    April 18, 2015 at 6:07 am
    Thanks a lot…that’s working
  • Drew Lahat
    July 18, 2015 at 5:26 am
    Nice, I just happened to carry out this same workflow myself (before seeing this thread). Resolve is definitely a useful middleman conform tool in this case. It “speaks” both AAF and XML, and speaks AAF better than Premiere.
