Activity › Forums › Avid Media Composer › avid mc6 with proTools
  • avid mc6 with proTools
    Posted by Peter Groom on July 11, 2012 at 11:20 am
    HI
    Im thinking about adding Pro tools 9/10 onto my current “home” edit system with MC6 currently running on win 7 64.
    Does anyone know of any specific problems with running the 2 on the same machine and any specific installation orders / requirements to follow.
    I had it in my head that Id to d register and uninstall avid, then add Pt then re install avid.
    Peter
    Post Production Dubbing Mixer
    Chris Conlee replied 14 years, 2 months ago 4 Members · 6 Replies
  • Daniel Frome
    July 11, 2012 at 12:00 pm
    I run mc6 and pt9 on the same system. Mc6 is just a serial number and Protools is dongled. Works fine.
  • Peter Groom
    July 11, 2012 at 1:04 pm
    so do i not need to uninstall avid before installing pt 9.
    Peter
  • Daniel Frome
    July 11, 2012 at 1:18 pm
    Nope.
  • Job Ter burg
    July 11, 2012 at 8:43 pm
    You ABSOLUTELY should UNINSTALL Media Composer first.
    See the Coinstall notes here:
    https://avid.force.com/pkb/articles/en_US/Compatibility/en354427
    * Install Pro Tools first and then Media Composer.
    * You must uninstall all older versions of Media Composer or Pro Tools before installing newer versions.
    * Co-install does not support both applications launched simultaneously.
    * Co-install of Pro Tools LE with Mbox 2 Pro is not supported with Mojo, Mojo SDI or Adrenaline due to Firewire conflicts.
    * Co-install was not qualified with Windows Vista 64.
    * When you uninstall Pro Tools, choose to uninstall just the application, not the audio drivers. On a Macintosh Pro Tools system, this is named the “Safe Uninstall”.
    * If you uninstall the audio drivers for Mbox or Mbox 2, Media Composer will no longer see these devices.
    * If you run into any issues, uninstall both applications and reinstall Pro Tools first, then Media Composer.
  • Job Ter burg
    July 11, 2012 at 8:45 pm
    P.S.: I have three PC’s and one Mac, all of them have had PT and MC (or Symphony) coinstalled. I have always stuck to the instructions in the co-install notes. For PT updates, I would uninstall MC/SY first, update PT, then reinstall MC/SY. And it always kept working.
    Thing is: both apps install some common files, and MC/SY demands these are of a certain specific version, and PT apparently is less critical about that (or is more compatible).
  • Chris Conlee
    July 20, 2012 at 5:00 pm
    Job’s advice is good. I installed PT on top of my Avid install a while back and over time started having some audio driver issues. When I recently uninstalled both and installed them in the “correct” way, the problems went away. I’d recommend being safe over sorry, even though it can be a bit of a PITA.
    Chris
