Activity Forums Blackmagic Design Avid MC6 and Hyper Shuttle DNxHD 185 problem
  • Avid MC6 and Hyper Shuttle DNxHD 185 problem
    Posted by Pekin Azer on June 29, 2012 at 1:21 pm
    Hi, i just upgraded to avid mc6 so i can use the footages i shot with the Sony F3 and hyper shuttle 2…
    i am planning on shooting my first siver screen film! i want to use The hyper shuttle 2.
    But, my PC based Avid mc6 can see the files, but, when i try to play them the footages won’t play and they look damaged. But, i can hook the shuttle via hdmi or hd-sdi to any monitor and all the material is good.
    what am i doing wrong?
    Pekin
    Andreas Wojtaschek replied 14 years, 2 months ago 2 Members · 3 Replies
  • Andreas Wojtaschek
    June 30, 2012 at 12:20 pm
    Make sure to copy all files from your hyperdeck SSD to the mxf media folder of you Avid system. Then go to the Avid mediabrowser and import the files into a bin. You can simply drag them into a bin.
    Make sure that the hyperdeck is set to dnxhd mxf file creation.
    Regards
    Andreas
    Entertainment Producer IHK
    mindandvision
  • Pekin Azer
    June 30, 2012 at 5:27 pm
    Thanks for the help, but, it’s not happening….
    Davinci Resolve doesn’t see the mxf’s either… i don’t know the version but, a friend’s davinci only saw the QT 1:1 files…
    What do i do? is anyone working with these mxf files…. i want my P2 panasonic!!!
    June 30, 2012 at 7:40 pm
    Check your workflow – It’s working without an issue here.
    Cheers
    Andreas
    mindandvision
