Activity › Forums › Adobe After Effects › Avid MC6 -> AE CS5.5
  • Avid MC6 -> AE CS5.5
    Posted by Randy Rubin on December 16, 2011 at 2:38 pm
    Hello,
    I’m looking to take my entire sequence from Avid and take it into After Effects. I know there is the plugin from Boris but I don’t want to spend the $300. I was wondering if there is a work around. I want the sequence in After Effects so that each clip is on it’s own layer (which is why I don’t just export a quicktime). Using automatic duck I get this error.
    The effects I have on the footage are timewarp (I’ve tried this with both fields rendered and fluidmotion) and CC. When I look at the footage in AE certain clips are stuck like freeze frames.
    A thought I had was exporting an EDL and bringing it into premier but after some research it looks like I would have to relink the clips one by one. I also don’t know if the effects that I have on the footage would remain in tact.
    On a side note, when I was exporting an AAF I tried consolidating all of the media. It ended up not working, and I wanted to confirm that deleting the master clips and associated media files wouldn’t affect my original mxf files. My understanding is that when I consolidate it generates new media.
    Any help would be much appreciated.
    Randy Rubin replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
