Avid MC Timewarp: when does it not apply?
Hi all, and forgive me if you’ve heard this before. I’m working in Avid MC at a new place that often throws me anamorphic video for me to reversion. My sequences are 30i 16:9, so Avid automatically “conforms” the footage with a standard “Flex” effect, stretching the footage out for me.
I’m mostly reversioning cut news packages for foreign language use. Because the new dubbing audio track doesn’t always match the footage, I’ve found the “trim to fill” effect to be my new best buddy. BUT, sometimes it simply doesn’t work. Avid won’t let me use it on a clip, saying it doesn’t apply, that the original footage doesn’t match the sequence or something like that. And, yes, sometimes I’m able to force it to work by “promoting” the clip in the Motion FX window and manually stretching the time to fit my needs.
But sometimes, it doesn’t even let me do THAT.
So I’m looking for guidance and support. What is it about some clips or some footage that Avid refuses to allow a motion FX or time stretch effect to be used? Is there anything I can do to be sure the clips are always going to work correctly? I’m guessing someone will tell me to just transcode all clips on AMA import, but I don’t think that works every time.
Any similar situations or workflow suggestions? Thanx, Dave.
