Activity Forums Avid Media Composer Avid MC 8 jittery playback issues with MacPro OS 10.10.3
  • Avid MC 8 jittery playback issues with MacPro OS 10.10.3
    Posted by Maria Wardian on July 22, 2015 at 9:54 pm
    In editing a short form project in Avid MC 8.4, we are getting a jittery and skippy video playback consistently even though we’re watching at half res (green/yellow), rendering fully and often with no color bars on timeline, using a powerful MacPro, and have only one editor working off this media partition on our Facilis server. For client viewing, we are connected to a Panasonic TV through an AJA ioXT. It seems to get bad enough for a need to restart the whole computer, which helps for a short while. Any tips on how to optimize our set up and avoid so many restarts?
    More details on the setup:
    MacPro cylinder (Late 2013OProcessor: 3.5 GHz 6-core32 GB ramGraphics: AMC FirePro D700OS: 10.10.3Avid MC 8.4. Project is 1080p 23.98, RGB 107.
    Media: We ingested DNxHD encoded QTs and some ProRes4444 to a 1920×1080 23.98 project DNxHD 36 mxf. Avid media is on it’s own a separate partition from the project, all only being used by one editor at a time with plenty of space.
    Server: Facilis version 6.2, restarted 1-2 times/week, connected out via ethernet.
    Monitor out to Panasonic LCD TV through AJA IoXT HDMI out.
    AJA with latest software and driver (install 12.2.1).
    AJA Format matches Avid sequence: 1920×1080 23.98, color space YUV 8 bit
    *It helps to disconnect the AJA for monitoring, but doesn’t completely solve.
    Edit: It’s short! 30 second commercials, some simple masking and scale/position keyframes.
    Thanks for any input!
    Maria W
    Joe Morris replied 10 years, 10 months ago 3 Members · 2 Replies
  • Bob Zelin
    August 1, 2015 at 5:52 pm
    are you getting jittery playback just on the AJA I/O XT output and Panasonic TV, or is it also jittery on the Mac computer screen when it plays back ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Joe Morris
    October 11, 2015 at 4:22 am
    I’ve been having the same issue on 8.3 onwards to 8.4.1.
    I have found if I “downgrade” and resinstall 8.1.0, it fixes the issue.
    Its very annoying.
    When 8.0 was released I had the same issue, 8.1 is the only release that the playback issue doesn’t occur with (apart from 7).
    Film Editor & VFX Supervisor
    http://www.joejmorris.com
    http://www.freelancefilmeditors.com
