Activity › Forums › Avid Media Composer › Avid MC 5.5 on an iMAC i7
  • Avid MC 5.5 on an iMAC i7
    Posted by Theo Raben on June 16, 2011 at 5:42 am
    Does anyone know if Avid MC 5.5 work well on an iMAC i7 (the newest fastests version)?
    Does it work without any problems for HD editing?
    I will connect an AJA IO express as soon it will be supplied with a thunderbolt connection.
    Thanks for the advice.
    Theo Raben
    Jeff Greenberg replied 15 years ago 4 Members · 6 Replies
  • Brendan Maghran
    June 17, 2011 at 8:50 pm
    The new imacs will work wonderfully. I’m currently running it on an older model just fine.
  • Jeff Greenberg
    June 18, 2011 at 1:30 am
    Works great. Just taught a class using them.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Molly Mckinley
    September 1, 2011 at 5:52 pm
    Can someone tell me how best to configure the iMac for editing. I understand that it should have the 3.4ghz processor. What about memory and hard drive? anything else a must-have?
    I edit mostly verite doc-type shows, with some effects, but not effect heavy. Using an external drive. Might be doing a film with a lot of flat art and stills to be manipulated. I’d like to be equipped, but don’t want to spend a mint getting all the bells and whistles if I don’t need them.
    thanks!
    Molly
  • Jeff Greenberg
    September 1, 2011 at 6:12 pm
    Currently speaking according to this Avid document you don’t need the 3.4 ghz processor, but it’s a good idea.
    Memory: the minimum is 4. I’d suggest 8…and the current models can do 16 (for today, eh, for tomorrow, yeah!)
    Make sure you’re getting the Radeon Graphic card (although it doesn’t look like you get a choice beyond 1gb or 2gb on the card.)
    The stock drive is 7200 RPM – you could use it in a pinch. Make sure your external drives are that speed.
    The biggest suggestion I have for you? Is a hardware RAID 5 from someone like Gtech – to protect all that media you’re editing.
    Best,
    Jeff G
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
  • Molly Mckinley
    September 1, 2011 at 6:56 pm
    Thanks Jeff.
    Is there an advantage to working off the internal hard drive? Would it make more sense to soup that up and not use an external? (except for having the backup RAID)
    m
  • Jeff Greenberg
    September 2, 2011 at 12:05 am
    There are no advantages, no. We generally have media external to our OS/Application drive to have less stress on the pipeline in general – and just in case you accidentally fill up your internal drive. It’s such a common mistake that Avid has s Media Setting to help you not make that mistake.
    Best,
    Jeff G
