Activity Forums Adobe After Effects Avid MC 3 MXF QT ref export not importing correct in AE cs4
  • Avid MC 3 MXF QT ref export not importing correct in AE cs4
    Posted by Brian Mills on January 27, 2009 at 3:37 pm
    Im having a problem when i import a QT ref file made from Avid MC3. When I import the qt ref it is a white frame with no audio. Any ideas?
    B
    Brian Mills replied 17 years, 3 months ago 26,413 Members · 1 Reply
  • Brian Mills
    January 27, 2009 at 6:02 pm
    its on the same machine as the avid…the files came from a panasonic 170 720 30PN going into an Avid 30i project…everything is fine until i try and export a QT ref…then the file is all white…the WT ref works fine with OMFI files…
