Activity Forums Avid Media Composer Avid Log Exchange and Excel
  • Avid Log Exchange and Excel
    Posted by Steve on August 22, 2013 at 5:59 pm
    On a separate subject, does anyone know how to format an Excel file in such a way that can be imported into an Avid as logged clips?
    Thanks again.
    Steve
    Michael Phillips replied 12 years, 11 months ago 2 Members · 1 Reply
  • Michael Phillips
    August 22, 2013 at 7:09 pm
    Save out as a TAB file, then run it through Avid Log Exchange which takes in TAB and export ALE. Or you can add the global header from another ALE into the file.
    Top Row are column names but must match Avid’s uppercase/lowercase exactly. I would suggest exporting a TAB from MC and using that as a template. Also make sure the exported or save-as TAB file has proper “returns” after each clip data’s entry. Especially the last line in the file.
    Michael
