Activity Forums Avid Media Composer Avid Locator BIN Color
  • Avid Locator BIN Color
    Posted by Nick Pappanicholas on October 1, 2009 at 3:39 pm
    I’m Editing on an AVID Media Composer Mojo DX… So, I’m in a dark room all day, and my Locator bin is Gray with Black text… needless to say, the contrast leaves a lot to be desired…
    Is there any way to make the background of the locator window WHITE ?!?!
    I’ve looked in the settings… tried every menu there is… nothing… Anyone have any ideas?
    Nick Pappanicholas replied 16 years, 11 months ago 2 Members · 2 Replies
  • Joe Womble
    October 1, 2009 at 4:04 pm
    Nick,
    To change the color of your bin background open the bin that you wish to change – if already open, click on the bin window once.
    In the Edit menu at the top of the screen, scroll down to “Set Bin Background” and select the color you wish to use.
    Note: This color will be the default background color. If “Bin Default Background” is deselected under your chosen interface setting, the bin background will be white.
    Regards,
    Joe Womble
  • Nick Pappanicholas
    October 1, 2009 at 5:59 pm
    Thanks for the quick reply… But, perhaps I used the wrong term…
    It’s not a BIN I wish to change the color of, it’s the Locator Window….
    I open the Locator window after I first launch Avid MC… it’s White… Then, when I make my first revision to a locator someone else has left, the Locator Window turns Gray… Can’t get it back to White, or change the Font size for that matter…
    Nick
