Avid Interplay w/ Adrenaline / Unlinking Master Clips issue.
Hello All,
At my job we’ve just updated from Media Composer 9.2.3 running on OS 9 to an Adrenaline with ISIS, using the Interplay engine. I am a digitizer and I relied heavily on unlinking, then batch capturing my master clips which I created (I digitize Iso footage from 3 tapes that run simultaneously with identical Time Code on each tape.) I would log my first bin then duplicate —-> Unlink—-> Rename —-> Batch Digitize , repeat 3x. ie:\
Each in their own bins:
9582 5D Line Cut
9582 5D ISO B
9582 5D ISO C
9582 5D ISO DI heard that using Interplay I will not be able to unlink my clips – meaning I will have to re log everything each time. That would make my job much more tedious since all of the bins I create are identical- the only thing that changes are the tape name, and the Clip name.
Does anyone have any ideas on how I can duplicate my master clips and not have to re log- without screwing up my original clips from the first tape?
Thanks in advance.
Steve
