Activity Forums Avid Media Composer AVID import colour settings
  • AVID import colour settings
    Posted by Tom Bailey on November 20, 2011 at 11:13 pm
    I am returning to a project I shot on P2 and have problems with the image that I never managed to resolve.
    The image always comes out as if the gain has been turned up on all of it, with muddy blacks and colours.
    I can’t work out what the source of this problem is. Here are my settings:
    FORMAT:
    Raster Type: Standard
    Project Type: 1080i
    MEDIA CREATION> IMPORT:
    I have tried both DNxHD 120 MXF & DVCPro HD MXF
    IMPORT SETTINGS- IMAGE:
    Field Ordering in File:
    Odd ordered
    File Pixel to Video Mapping:
    Computer RGB, dither image colours and 601 SD or 709 HD
    Alpha Channel:
    Invert on Import
    I have made the discovery that if i export the video as ‘Same as Source’ and tick the ‘Use Avid DV Codec’ with colour level RGB, it comes out close to the original.
    A had the same result with the Apple ProRes 422 codec.
    This leads me to believe it may just be a displaying problem, but I can’t tell.
    Does anyone have any suggestions about what to try?
    Bailey.
    Tom Bailey replied 14 years, 10 months ago 2 Members · 2 Replies
  • Ed Cilley
    November 21, 2011 at 9:41 pm
    If you are importing P2, your settings for the File Pixel to Video Mapping should not be computer, but rather 601/709. Using computer RGB will stretch your video levels since they are 709 levels.
    Also, you could Ignore alpha channel if you like, but it won’t import if it doesn’t exist.
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Tom Bailey
    November 22, 2011 at 9:46 am
    Thanks Ed,
    I will try this.
    Bailey.
