Activity Forums Avid Media Composer AVID HD to SD XDCAM workflow
  • AVID HD to SD XDCAM workflow
    Posted by Miłosz Koziol on October 4, 2012 at 7:08 pm
    HI!
    In very near future I ll be editing a 4 camera political tv programm. It`s aimed at local TV station, wich still broadcasts in SD. I have 4 cams – 2 EX-3 wich can only record in HD and 2 EX-1r. I planned to shot it on 1080p and later multicam it or edit it directly on a timeline (due to budget here is no mixing at all). I`ll export rendered sequence into XDCAM broadcast PDW1500. Now…
    Firstly I cannont export sequence on ama can i ?
    Secondly – should I drop 1080p for 720i since PDW1500 cant ingest progressive material and since I have like 4 hours to deliver the show after we finish recording (it will be aired same day it was shot).
    Thirdly, I plan to edit it directly on the set with macbook pro and export it to PDW1500 XDCAM – should I use a ilink or SDI from ultrastudio extreme? Can I maybe ingest an HD sequnce and shrink it to SD in real time?
    I`m really confused…
    Miłosz Koziol replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
