Activity Forums Avid Media Composer Avid HD 5 burning to DVD
  • Avid HD 5 burning to DVD
    Posted by Patrick Bronte on August 5, 2006 at 5:20 am
    i’ve only just got back into it after a year off, installed Avid HD 5 and already I feel like such a cabbage for i cannot seem to get my sequences burnt to dvd. i’ve tried exporting a QT movie file then useing a third party vob file convertor but it wont recognize the QT files. is there someone with enough patience out there who can walk me through the best process of getting a sequence from avid hd 5 onto a dvd while maintaining the best possible quality??
    Jon Zanone replied 20 years, 1 month ago 2 Members · 1 Reply
  • Jon Zanone
    August 5, 2006 at 12:43 pm
    Start here –
    https://www.avid.com/exchange/forums/thread/4408.aspx
    Scroll down to the ‘How to DVD’ link.
    The basics for interlaced NTSC products are this (keep in mind this is from memory; if something is letter perfect, interpolate!) –
    Right click your sequence>send to> encoding>Sorenson (assuming you have Sorenson installed)
    A window will pop up – set your destination, and click options. Select Quicktime reference, native dimensions and 601/709
    click OK, then again, and Sorenson will open (again, assuming you have Sorenson). Under MPEG2, select and drag the LG_DVD_NTSC setting to your job window. Double click on the setting, make sure your data rate doesn’t exceed 9000kbs(?). I’ve had great results with data rates as low as 3000 and as high as 6000. Select either program (embedded audio) or elementary (seperate audio and video files) Select 6 i frames. Under the filters, double click the first one (it doesn’t matter – your going to change it), uncheck everything except normalize audio. Make sure auto-deinterlacing is OFF (Sorenson does a horrble job of deinterlacint video). Save the preset as ‘auto deinterlacing OFF’, and apply that as well. click squeeze it. I use Reel DVD, but I won’t bore you with those details unless you want me to.
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
