Activity Forums Boris FX Avid FX 5.8.3 Problems/Crashing
  • Avid FX 5.8.3 Problems/Crashing
    Posted by Harrison Holmes on July 13, 2011 at 4:22 pm
    Running MC 5.5.2.1 on Mac Pro (early 2008) 2x3Ghz 16Gb RAM w ATI Radeon HD 5770 & on MacBook Pro (early 2011) 2.2 Ghz i7 8Gb RAM w AMD Radeon HD 6750M – both running OS 10.6.7 – Avid FX 5.8.3 Standalone crashes on both systems when attempting to use the pen tool:
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000013
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Console indicates:
    7/13/11 10:43:12 AM /Applications/Avid FX 5.8/Avid FX 5.8 Engine.app/Contents/MacOS/Avid FX[1333] ATS: Invalid FontObjectID (3) – only low 16 bits are being passed in.
    7/13/11 10:43:54 AM Avid FX[1333] Avid FX(1333,0xa057e540) malloc: *** error for object 0x1dcb890: incorrect checksum for freed object – object was probably modified after being freed.
    *** set a breakpoint in malloc_error_break to debug
    7/13/11 10:43:54 AM [0x0-0x71071].com.borisfx.app.Avid FX[1333] Avid FX(1333,0xa057e540) malloc: *** error for object 0x1dcb890: incorrect checksum for freed object – object was probably modified after being freed.
    7/13/11 10:43:54 AM [0x0-0x71071].com.borisfx.app.Avid FX[1333] *** set a breakpoint in malloc_error_break to debug
    7/13/11 10:44:00 AM com.apple.launchd.peruser.501[144] ([0x0-0x71071].com.borisfx.app.Avid FX[1333]) Job appears to have crashed: Bus error
    7/13/11 10:44:00 AM ReportCrash[1342] Saved crash report for Avid FX[1333] version 5.8 (1.0) to /Users/harrisonholmes/Library/Logs/DiagnosticReports/Avid FX_2011-07-13-104400_Harrison-Holmess-MacBook-Pro.crash
    There seems to be no information what-so-ever regarding this issue, although I found two posts from users experiencing crashes with the application and receiving the identical error and “ats: invalid fontobjectid.”
    Also, when using Avid FX within Media Composer, often the values for many of the parameters do not update; this behavior is inconsistent and seemingly arbitrary. I assume my graphics cards are the culprit, but I have identical crash behavior with the pen tool using vastly different cards. Any thoughts?
    Thanks.
    Mac Pro 3Ghz 8-core
    16Gb Ram
    ATI Radeon HD 5770
    OS 10.6.6
    Aja Kona LHe
    Travis Wine replied 14 years, 8 months ago 4 Members · 4 Replies
  • Peter Mcauley
    July 15, 2011 at 7:41 pm
    Is this something that has just recently started to happen? If so, then what is different about the system … new font perhaps? Is it only with projects of a certain size? I’d suggest you get in touch with one of our support gurus who might be able to offer you some assistance in sleuthing the error.
    You can reach them via email at support@borisfx.com
    Cheers,
    Peter.
  • Harrison Holmes
    July 20, 2011 at 2:14 am
    Peter, thanks for the response; sorry I haven’t checked back to this post in a few days. Marianna over at the Avid forums put me in touch with their tech support; no solution at the moment (apparently my issue is a real anomaly), but they’re looking into it. When I hear something, I’ll post back here. Thanks.
    Harrison
    Mac Pro 3Ghz 8-core
    16Gb Ram
    ATI Radeon HD 5770
    OS 10.6.6
    Aja Kona LHe
  • Tony Giammarino
    October 25, 2011 at 3:29 am
    I am extremely excited about becoming a new Avid Media Composer user. Unfortunately, I am experiencing a problem with Avid FX crashing. Whether files are transferred from MC or FX is used as a stand alone, the least usage of the FX program courses it to close and indicate an “unexpected quite”. I was wondering if anyone else experienced the same and found a solution to the problem.
    I am working on an IMac 27″ with 8GB of ram. I haven’t experienced this with any other software. I contacted Boris, Apple and Avid and still do not have the answer.
    Oh, also, I did upgrade to 5.5.3 as directed by Avid for use with the Imac and the problem still exist.
  • Travis Wine
    December 31, 2011 at 10:02 pm
    I honestly think it has to do with the graphics. I know that Avid Fx is a part of Boris or should I should say a Boris codec. They only admire nvidia drivers. I have an early 2009 mac pro. My nvidia gt120 card installed runs avid fx stable, however if I put in my ATI 8750 thats a recommended card from Apple, it crashes all the time.
