Activity › Forums › Avid Media Composer › “Avid-friendly codec” for PC
  • “Avid-friendly codec” for PC
    Posted by Bob Cole on January 21, 2011 at 3:36 am
    I’m editing ProRes422 files, HD, in FCP, but need to send a hard drive full of files for an Avid PC-based editor to use. He prefers an “Avid-friendly” codec.
    What’s the best thing I can create on the Mac in FCP for him?
    Bob C
    Michael Kammes replied 15 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Michael Kammes
    January 21, 2011 at 4:10 am
    DNxHD, which is Avid’s HD codec.
    In a perfect world, the DNxHD codec would be in an MXF wrapper, however, few programs can do both a DNxHD encode AND place it into an MXF wrapper. Thus, best practice is to create a DNxHD Quicktime file into a format, that Avid can FAST IMPORT.
    Shameless Self Promotion: I penned an article on it, which outlines how to do it and why: https://michaelkammes.com/encoding/avid-is-self-aware-fast-import/
    This allows Avid to import a file into an MXF wrapper, which performs better than the Avid 5.0+ AMA via Quicktime workflow.
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
  • John Pale
    January 21, 2011 at 4:48 am
    You did not specify whether its HD or SD.
    Avid DNXHD is HD only, unlike Apple ProRes.
    If its SD, you will want to use Meridien 1:1.
    This is all in the Avid Quicktime Codec package.
  • Michael Kammes
    January 21, 2011 at 7:21 am
    Correct. However, the original poster did say HD.
    ~Michael
  • Bob Cole
    January 21, 2011 at 12:39 pm
    [Michael Kammes] “However, the original poster did say HD.”
    Thanks very much to you both. Actually I edited the post to add “HD” after a couple of minutes, so John was probably right too.
    The instructions in the article were absolutely over-the-top helpful and excellent, with links and everything. It worked!
    Thank you so much for an excellent reply.
    Bob C
  • Bob Cole
    February 5, 2011 at 3:31 am
    I downloaded the Avid HD codec and thought I had followed the recommendations in Michael’s guide, but the Avid editor just sent me some frame grabs which show that only the top half of the video frame came through. Does that ring a bell?
    Bob C
  • Michael Kammes
    February 5, 2011 at 4:05 pm
    I would verify what version of Avid DNxHD codec package you have on your system…your codec pack may be older than the ones on his system. Avid has made slight changes to the DNxHD codec over the past few years, that could be the culprit.
    https://www.avid.com/US/industries/workflow/DNxHD-Codec
    Hear me pontificate: Speaking Schedule .
  • Bob Cole
    February 8, 2011 at 6:10 pm
    Thanks Michael. I will try to figure out the exact Avid codec. There is also the possibility that the Avid editor has an older codec.
    What do you think would be the safest file format in which to export my Final Cut Pro movies? Is there some universal format which Avid editors can import?
    Bob C
  • Michael Kammes
    February 8, 2011 at 7:26 pm
    That’s a loaded question.
    Avid v 5.0+ can use AMA to link to almost ANY QT based file, without having to re-import it. Thus, you can export almost any format from FCP, and Avid will see it. The only hitch being there has to be the same codec on both machine.
    The safest bet is to skip AMA, and use the old reliable method and import. Best practice to generate a file for fastest import into Avid, and is listed in one of my initial replies to this thread:
    DNxHD is probably your best bet, all Avid’s made in the past 5 years understand it.
    ~Michael
