Activity › Forums › Avid Media Composer › Avid Format Question
  • Avid Format Question
    Posted by Matthew Stewart on October 18, 2012 at 6:10 pm
    I’m trying to import an h.264 file that is from a dvd, the video is sized 960 x 640, is there a way to immport this into avid and set it up for that size? When I create a project I can only select 720 or 1080. How I can I import the file and edit it at the best resolution possible and export it without losing any original quality?
    Trevor Asquerthian replied 13 years, 11 months ago 3 Members · 3 Replies
  • Shane Ross
    October 18, 2012 at 6:31 pm
    Avid only works in broadcast frame sizes. And that file is neither. Your options are 1920×1080, 1280×720, 720×486 and 720×480. If the file came from a playable DVD, it should be 720×480.
    Shane
    Little Frog Post
  • Matthew Stewart
    October 18, 2012 at 7:23 pm
    ok, thanks!
  • Trevor Asquerthian
    October 18, 2012 at 7:44 pm
    You could import them with ‘do no resize smaller images’ in the next size up broadcast raster – and do a crop back down to the native size at the end in some other programme (compressor?)… if you really need to keep that size.
