Activity › Forums › Avid Media Composer › Avid File importing
Avid File importing
Posted by Derek Jones on January 17, 2010 at 7:46 pmHi All
Sorry I did this post before but couldn’t find it in the list… 🙁 So here is is again.
What are the accepted file types and codecs that can be imported into AVID…
Many thanks in advance
DelJ
Nicole Morse replied 16 years, 8 months ago 4 Members · 4 Replies -
Bouke Vahl
January 17, 2010 at 11:07 pm1) Anything QT compatible
2) everything else listed in the help function
3) everything that you find that falls not under 1 or 3, but works anyways.Now for the million dollar question:
What are you after?Bouke
https://www.videotoolshed.com/
smart tools for video pro’s -
Shane Ross
January 18, 2010 at 4:25 amWhatever you import, Avid will convert to MXF or OMFI…as it doesn’t work with ANY QT codecs natively.
Shane
Read my blog, Little Frog in High Def -
Bouke Vahl
January 18, 2010 at 10:34 amShane,
Not quite the way i see it.
If you import a QT with one of the Avid codecs, Avid will not transcode, just rip the content out of the QT. (and yes, it’ll put a copy in the OMF or MXF media files directory)Now we can fight if the codecs are Quicktime codecs compatible with Avid or Avid codecs compatible with Quicktime, but that does not really matter.
It does work ‘natively’ with it’s own codecs, and those codecs are QT compatible.
But the question remains what the OP is after…
Later,
Bouke
Nicole Morse
January 21, 2010 at 3:45 amKeep in mind as well that you can drag and drop movie files into bins in many cases, but that going through the File –> Import menu is usually (in my experience) more stable.
