Activity Forums Avid Media Composer Avid fast import?
  • Avid fast import?
    Posted by Sandy Moore on August 25, 2011 at 5:17 am
    I am trying to use the “fast import” in avid..I have already transcoded my footage in mpeg streamclip and am now trying to fast import but 15 clips have taken 4 hours so something must be wrong..my import settings are set to 601 not RGB…can anyone tell me what i am doing wrong, what are the correct settings to fast import or if i did everything right and it’s just taking that long???
    Michael Kammes replied 14 years, 12 months ago 5 Members · 4 Replies
  • Andrew Mckee
    August 25, 2011 at 9:48 am
    If you are doing a fast import it would say “fast importing” in the box. Are you certain you transcoded to a frame rate, frame size and codec that matches your project precisely? Any reason you are choosing to use MPEG streamclip to convert files rather than just importing in to Avid or AMAing and then transcoding?
    Andrew McKee
    Editor/Colourist
    Avid Certified Instructor – MC5.5
    Apple Certified Trainer – FCP7
    Pixelwizard.net
  • David Budnetz
    September 1, 2011 at 4:55 pm
    Fast import only works with certain codecs that have native media composer support. I do not have the documentation in front of me, but I seem to recall fast import only working with avid codecs and ikegami GFcam mxf files.
  • Jeff Greenberg
    September 1, 2011 at 6:18 pm
    You didn’t ‘hit the mark’ with the settings in MPEG Streamclip. It has to be a DNxHD codec for HD and an Avid meridian codec for SD. You need to nail the sizing of the clips; If you get the settings right in MPEG Streamclip, they’ll fast import. If not, the avid senses it has to recompress. FWIW, you could just use the clips via AMA (if they’re clips and not a DVD)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Michael Kammes
    September 3, 2011 at 8:06 pm
    I wrote up a doc on this which may help.
    https://michaelkammes.com/encoding/avid-is-self-aware-fast-import/
    ~Michael
    .: michael kammes mpse
    .: senior technology & workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    .: twitter: @michaelkammes
    .: facebook: /mkammes
    Hear me pontificate: Speaking Schedule .
