Activity › Forums › Avid Media Composer › AVID Express
AVID Express
Posted by Drsmooze on May 16, 2006 at 7:07 pmAny tips on how to avoid bleed through onto other tracks from nested color correction?
Drsmooze replied 20 years, 4 months ago 3 Members · 4 Replies -
Couscous
May 17, 2006 at 10:55 amHello Chris,
Are you talking about Meridien Xpress, Express DV or Express Pro HD? In which kind of situation/ or point of workflow this bleed through occured? I just tried recreate the problem In Xpress Pro HD 5.2.4 and couldn’t do that. Are you sure that your sw is legal. I have heard about many weird problems in cracked sw’s.
BR
CousCous -
Geraint Pari huws
May 17, 2006 at 11:00 amstep in to the bottom layer in the nest…ie color correct the shot at the lowest poss level, stange but true…
Drsmooze
May 17, 2006 at 5:49 pmThanks for the response, the sw is “old school” AVID Express DV 2004.
