Activity Forums Avid Media Composer Avid Express to firewire drive
  • Avid Express to firewire drive
    Posted by Tom John on October 2, 2005 at 7:59 pm
    Hi, all,
    I have some Beta SP footage I need to convert to DV25 and move to my FCP system. The only Beta machine I have access to is with an Windows-based Avid Express system elsewhere. How can I do this? Will the Avid let me capture and then export to a LaCie firewire drive through the Mojo? And then will my Mac read from that drive? Or do I have to export to Mini-DV tape instead?
    -Tom
    DesertVideo@earthlink.net
    Michael Phillips replied 20 years, 11 months ago 2 Members · 1 Reply
  • Michael Phillips
    October 2, 2005 at 10:09 pm
    On the Windows based machine:
    Make sure the Mojo and the FireWire Drive are on different buses. Then capture.
    If they are not, capture to a supported drive first (internal for example) then copy files to the FireWire drive.
    You then need to make sure you can mount the drive on a Mac OS system. What I have done is used MacMounter on the PC and captured directly to the that drive. The move to a Mac ystem.
    Now -getting that footage to the FCP system… I would just capture first to the Avid XPress internal, then export as self contained QuickTimes to the firewire drive.
