Activity Forums Avid Media Composer Avid Express 3.0 HELP
  • Avid Express 3.0 HELP
    Posted by Robert Kazden on July 5, 2006 at 12:46 am
    I bought avid express about 3 years ago along with a compaq workstation….and really i knew nothing about…well anything…except how to edit. When i bought it, they came to my house, and set everything up for me…installed it…customized it..everything, so it was ready to use. okay so, just last week, my hard drive crashed and had to be replaced, and i had to reinstall everything.
    after reinstalling avid, everything seems to be out of whack. for starters there doesn’t seem to be a default workspace set up. the timeline is off to the side, the viewing windows are all over the place and when i try to move them, they snap around, sometime even off screen. and on top of that, i can’t capture. while my camera is connected i can autoconfigure the deck and it reads as being there, but when i click the video button on, it says there is no input signal present. i used to get that message when the camera wasnt hooked up right, but everything seems fine to me. what am i doing wrong? would i have these problems if i upgraded to pro?
    windows 2000 avid express 3.0
    thanks for any input.
    Kenton Vannatten replied 20 years, 2 months ago 2 Members · 1 Reply
  • Kenton Vannatten
    July 5, 2006 at 8:47 pm
    There’s a couple things that could be causing your issues, but off the bat, I’d guess that you don’t have the video card display drivers installed correctly (likely wrong version)
    Or it’s possible that you have your monitors set up incorrectly, if you have the Primary monitor set to be the right, then you will get the windows jumping around behavior with certain video cards.
    Did you delete your settings files too when you re-installed or did you back them up to a safe location prior to re-installing?
    I’m not sure about the capture issue right now, What FW card do you have installed?
    PS, it’s been awhile since you’ve posted your question, you may get more urgent/frequent viewers on the Avid Commnuity Forums… here is a direct link to the XpressDV (for PC) forum. https://avid.com/exchange/forums/47/ShowForum.aspx
    Good luck.
    Kenton VanNatten
    Avid Editor (for hire)
