Activity Forums Adobe After Effects avid exported quicktime, showing white
  • avid exported quicktime, showing white
    Posted by Rosy Rodrigues on September 10, 2005 at 2:08 pm
    I have got my avid editior to tranfer a movie clip to me as a quick time movie. but when i open it in my system the video comes as white. the audio however is fine.
    what is the problem. am i missing someting on my system. i dont have any problem in playing other quicktime movies on my sysytem otherwise. its only the one i get exported from the avid as a clip.
    Rosy
    Hank replied 21 years ago 6 Members · 8 Replies
  • 8 Replies
  • Chris Smith
    September 10, 2005 at 2:14 pm
    Under your comp window, is the alpha channel (whire button) the only thing engaged?
    When you play this quicktime just from the QT player is it still white?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Rosy Rodrigues
    September 10, 2005 at 2:24 pm
    it show as white even outside after effects Chris.
    Rosy
  • Chris Smith
    September 10, 2005 at 2:26 pm
    Then I would put the problem at the Avid side. I wonder if it still shows white on the PC in the quicktime player on the Avid machine. If it is showing white, then I think it’s an AVID Cow question me thinks.
    Chris Smith
  • Satesh Ramjattan
    September 10, 2005 at 2:34 pm
    it is most likely the codec the avid is using. try a different one, depending on what you want, “photo jpeg” is good, so is “animation”.
  • Steve Roberts
    September 10, 2005 at 3:25 pm
    Yep, it sounds as if your machine doesn’t have the necessary codec.
    Steve
  • Jim Zito
    September 10, 2005 at 6:18 pm
    You might wanna make sure you have the latest version of Quicktime.
  • Steve Roberts
    September 10, 2005 at 7:38 pm
    Or at least, Quicktime 6.5. 🙂
    Steve
  • Hank
    September 10, 2005 at 8:12 pm
    you need to install the avid quicktime codec.
    https://www.automaticduck.com/support/
