Activity Forums Avid Media Composer Avid Export settings to DVD
  • Avid Export settings to DVD
    Posted by Newavideditor on January 3, 2006 at 6:19 pm
    Hello everyone,
    I’m trying to get an Avid Adrenaline project(Mac OS 10.3.9, Avid 1.6.7) to iDVD 5.01 without any luck. I get a blocky image (looks like DVcam when fast fowarding) on any shot that pans.
    Should I compress the video using Sorenson Squeeze (Ver. 4.1)? If so, what would be the settings? Would I still export from avid as a quicktime ref?
    If anyone can help I would really appreciate it.
    Thanks for reading,
    Eric
    Jon Zanone replied 20 years, 8 months ago 3 Members · 2 Replies
  • William909
    January 3, 2006 at 9:04 pm
    I have never worked with iDVD but with DVD Studio Pro I’ve found that exporting as a Quicktime Movie and clicking the “Same As Source” button works great (don’t use the Avid DV Codec). However, originally capturing your Avid footage at either mixed resolutions or at DV 25 411 often causes issues. You can do a video mixdown of your whole sequence to 2:1 OMF and then export it if you’ve captured as described above.
    Good Luck,
    Will Meyer
    Sure Shot Productions, Inc.
  • Jon Zanone
    January 4, 2006 at 12:54 pm
    If you’ve got Sorenson, use it.
    I don’t work Adrenaline (MC Meridian Mac & AXP PC are my platforms of choice…), however, I’ve found the following through trial and error –
    -Don’t use the Avid to export anything other than a QT Reference – and export it by right clicking the sequence in the bin, and select send to>encoding>(assuming you have Sorenson installed)Sorenson. Once there export native dimensions. Don’t let Avid do anything to your file. I have had absolutely no luck letting Avid convert my file in any other way than native dimensions.
    -Make sure you turn off ‘auto de-interlacing’ in Sorenson. I don’t remember what version is which, but it’s either a little wrench at the top of the window, or you have to create a new filter and apply it each time.
    -Once in Sorenson, start with a data rate of around 5000, and set your I-frames to 12. That will provide a good starting point.
    HTH,
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
