Activity Forums Avid Media Composer AVID export QuickTime
  • AVID export QuickTime
    Posted by Emma Mcneill on February 21, 2007 at 7:27 pm
    Hi there
    can Avid Xpress output files in QuickTime format in a variety of codecs (DV-PAL DVCPro50, etc) even on the PC version without having QTPro? Also, can the freebie version do that?
    thanks for your time
    Emma
    Emma Mcneill replied 19 years, 6 months ago 2 Members · 2 Replies
  • Carl Amoscato
    February 22, 2007 at 1:54 am
    The current version of Xpress Pro will allow you to output Quicktimes with a wide range of codecs (just checked on my Xpress DV 4.8 machine and DV-PAL and DVCPro50 were both available).
    If you’re talking about an older Xpress machine, you may or may not have as many options.
    Free DV is more limited, but if I recall correctly you can still export Quicktime movies with whatever codecs are installed on your system.
    good luck,
    Carl
  • Emma Mcneill
    February 22, 2007 at 12:40 pm
    Cheers big ears!!
    ;o)
    Emma
