Activity Forums Avid Media Composer Avid Export problem
  • Avid Export problem
    Posted by Dave Boampong on October 9, 2007 at 6:28 am
    I am using Avid Xpress Pro 4.5 and an external Maxtor firewire drive (500G/ 7200rpm/ Win Xp SP2/ 1G ram/60G internal drive). When I try to export a quicktime reference file for encoding to DVD the process stops about halfway, and the firewire drive goes off. Then the process finishes with errors. My Omf files are on the external drive. Is there a problem with the drive? My project is 9 minutes long and in PAL.
    Dave
    Dave Boampong replied 18 years, 11 months ago 3 Members · 4 Replies
  • Michael Phillips
    October 9, 2007 at 10:15 am
    If your drive shuts down, then there is a problem with the drive… can you consolidate to another or the internal drive to export from there?
    Michael
    anything 24fps
  • Dave Boampong
    October 9, 2007 at 10:53 am
    I will try that thanks.
  • Grinner Hester
    October 9, 2007 at 1:34 pm
    dont forget the mixdowns.
    you’ll have interlacing galore otherwise.
  • Dave Boampong
    October 12, 2007 at 7:34 am
    Thanks. Sorry for not responding earlier. I was out of town.
