Activity Forums Avid Media Composer Avid Effect Help
  • Avid Effect Help
    Posted by Mark Tyson on January 29, 2010 at 10:51 am
    Hi guys, 1st post, glad to be apart of the cow.
    Ok, an effects query if some of you may know the answer to, I have seen this effect, but am unsure how it was done.
    I use Avid Composer and i am trying to figure out how to create an effect for a TVC i am working on where i have a static car composed in the shot, i am trying to create a moving rectangle window which when the magnified window pans across the car, we can see in it a magnified and more detail of the part of the vehicle as it goes across.
    I do not know what the effect is, but i think maybe its some type of mask?
    Thanx.
    Mark
    Grinner Hester replied 16 years, 3 months ago 2 Members · 1 Reply
  • Grinner Hester
    January 29, 2010 at 7:43 pm
    Use animatte to mask on/off the closer shot you’ll need for the magnification effect. Nesting a resize won’t work well as it will tear up the image quite a bit.
