Activity Forums DVD Authoring AVID DVD by Sonic — *field dominance?*
  • AVID DVD by Sonic — *field dominance?*
    Posted by Jason Brown on October 18, 2005 at 11:23 pm
    Hey, does anyone use this program?
    My friend needs help…I use Sonic DVDit, so I assumed it would be similar, but I like mine a lot better.
    He has a problem when he creates both:
    -A quicktime ref. exported from AVID Xpress
    -MPEG2 DVD spec with Sorensen Squeeze
    His problem is that when he burns the DVD, on an NTSC monitor, the picture flickers. I had this problem with DVDit, but was able to fix the problem by setting field dominance to “lower” by right-clicking on the media (within Sonic) and going to properties.
    I have researched this, and can’t find a field-dominance setting in AVID DVD by Sonic. I assume because it knows you will be importing AVID DV or D1 files which are by nature *lower field first*. But I can’t figure out why he is having this problem, and can’t work towards finding a solution.
    Thanks in advance for any help….
    btw,
    I love the cow!!
    Jason Brown replied 20 years, 10 months ago 2 Members · 4 Replies
  • Alex Alexzander
    October 19, 2005 at 2:07 am
  • Jason Brown
    October 19, 2005 at 2:19 am
    I followed this tutorial to the letter…it’s actually the first place I turned when we started having problems.
    Number one — The QT ref that I exported is (or should be) using the lower field dominance of the original digitized clip it is referencing.
    Number two — I did make sure in Sorensen that lower field was dominant in my MPEG2 encoding.
    Is it possible that it isn’t a field dominance issue? Anyone else had a problem like this?
    -Jason
  • Alex Alexzander
    October 19, 2005 at 3:01 am
    What is the source footage from specifically?
  • Jason Brown
    October 19, 2005 at 3:12 am
    The project was digitized from MiniDV shot with a Panasonic (don’t know model).
    Edited with AVID Xpress pro.
    And like I said, we have worked with exported QT ref & Sorensen compressed MPEG2 files. Both exhibit the same problem.
    -Jason
