Activity › Forums › Avid Media Composer › Avid DV Express HD won’t make edits
  • Avid DV Express HD won’t make edits
    Posted by David Eells on March 14, 2007 at 2:38 pm
    I’m working on a client’s rig, running Avid Express Pro HD 5.2.4 on Windows XP Professional 5.1 on a Xeon 3 gh with 3gb of ram. Seems like a good rig, but:
    I can’t make any edits using Splice-in or Ovewrite – I get a prompt that says insufficient video even though I have plenty of source video. I can drag and drop the clip into the timeline, but this is very clunky. I’m finding this happens no matter which user settings I use.
    Also, there seem to be NO effects available. Does Avid ship products without any effects whatsoever?
    Have mercy on me. I’m a media composer kind of guy, and I’ve been away.
    Erik Pontius replied 19 years, 6 months ago 3 Members · 5 Replies
  • James Burke
    March 14, 2007 at 3:59 pm
    As far as insufficient source, the play head isn’t parked on the last frame of the source is it?
    If you click on the effect tab in the project, there are no effects? If that’s the case, you may need to reinstall the software. All systems have at least basic effects.
    James Burke
    Creative Director
    mBlaze Multimedia Design, Inc.
    http://www.mBlaze.com
  • David Eells
    March 14, 2007 at 4:06 pm
    Hey James
    It didn’t matter where the playhead was parked or how I marked the clip.
    If it’s possible to load the Avid without effects, that must be what the client did. Wacky clients!
  • James Burke
    March 14, 2007 at 4:17 pm
    I don’t think it’s possible to do an install without any effects.
    James Burke
    Creative Director
  • David Eells
    March 14, 2007 at 4:42 pm
    Found the effects, still having issues with Splice and Overwrite. Also, weird sounding error messages from Windows like “Delayed Write Error-All Information Will Be Lost”
  • Erik Pontius
    March 15, 2007 at 1:28 pm
    “Delayed write failure” might indicate that one of the drives is failing. Do they have external attached storage like USB or firewire drives? Often delayed write failures happen when USB or Firewire drives are improperly removed. Might be that a drive is spinning down unexpectantly due to failure.
    Might want to do a little listen to see if you can hear any clicking or wind up/down noises from any of the drives.
    You might really advise this client to back up anything important on this system, then run XP’s error checking or some other diagnostic utility on the drives.
    Erik
