Activity Forums Avid Media Composer Avid Drag Trimming
  • Avid Drag Trimming
    Posted by Peter Williams on March 29, 2016 at 2:48 pm
    Does anyone know if there is a way of drag trimming (using the mouse), so that the trim head doesn’t stop at every edit?
    I have a music track that I have cut into multiple times when making adjustments to a scene, and I need to drag it from the first edit point to the end of the scene.
    I have a feeling there is a key that needs to be held down, during the process, but I can’t for the life of me remember what it is (assuming it actually exists?!).
    Many Thanks
    Peter
    Peter Williams replied 10 years, 5 months ago 4 Members · 6 Replies
  • Juris Eksts
    March 30, 2016 at 12:56 pm
    I don’t think there is a quick way of trimming, but if you mark in and out on the entire clip, then:
    either 1, match frame and replace the clip, or
    2, in the audio mixer drop down menu – remove pan and volumes on entire clip, then in the clip menu – remove match frame edits.
  • Peter Williams
    March 30, 2016 at 1:09 pm
    Thanks Juris, I’ve have asked around, and there seems to be solution beyond doing what you have described1
  • Glenn Sakatch
    March 30, 2016 at 6:47 pm
    just remove match frame edits on your audio track
    Glenn
  • Juris Eksts
    March 30, 2016 at 9:56 pm
    Hi Peter, let us know when you find out.
  • John Pale
    March 30, 2016 at 10:36 pm
    You don’t need to drag at all. Just use Extend Edit and the clip will trim magically to wherever your play head is.
    For more information, search Your Avid Help.
  • Peter Williams
    March 31, 2016 at 8:00 am
    A FB forum suggests using extend edit or turning off snapping in the timeline settings. Someone posted this…
    https://www.steves-digicams.com/knowledge-center/how-tos/photo-software/how-to-control-clip-snapping-in-avid.html#b
