Activity Forums DaVinci Resolve Avid Dnx Quicktime wrapped .mov in Resolve
  • Avid Dnx Quicktime wrapped .mov in Resolve
    Posted by Dave Williams on February 10, 2012 at 5:37 pm
    I have a Dnx Seq. Quicktime wrapped .mov made in Avid on a PC based system. Resolve does not open this file. Is there anyway to modify this file to use? I have converted in QuickTime losing time code and that converted file works but after sending it back there were problems. Was just curious if there is a workaround for this. The codec on the .mov is AVdn.
    John Cox replied 14 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Juan Salvo
    February 10, 2012 at 5:45 pm
    You could try a fast import in avid then use the AVID mxf, which DaVinci can see.
  • Juan Salvo
    February 10, 2012 at 5:49 pm
    You can get a fully functional 30day trial of Media Composser, BTW.
  • Josh Petok
    February 10, 2012 at 6:51 pm
    Here’s how I’ve been doing it:
    Use “Link to AMA file” in Media Composer to bring the QT file in
    Select the clip and consolidate it. I believe this just rewraps the file as an MXF.
    After it’s done consolidating, right click the .new file and choose “reveal file”
    Move your file to a convenient location and add to your media pool
    Josh Petok
    Online | Color
    JoshPetok.com
    TheCurrentCut.com
  • Vladimir Kucherov
    February 10, 2012 at 7:08 pm
    Is it licensing cost that makes dnxhd quicktimes unavailable?
  • Juan Salvo
    February 10, 2012 at 8:01 pm
    Fast Import does the something. But I suspect faster and in fewer steps.
  • Dave Williams
    February 10, 2012 at 9:28 pm
    Thanks for all your help, I have Avid 5 just brought in the file and then used the MXF file it generated back to Resolve. Exported Dnx back to editor all worked great. I think next time we will try AAF and see how that flies, again thanks for your help.
  • John Cox
    February 24, 2012 at 9:38 am
    Is Resolve able to use DNxHD files created by the HyperDeck Shuttle with the new firmware that allows the video and audio files to be wrapped in a .mov file?
