Activity › Forums › Adobe Premiere Pro › AVID DNX Files in Premiere CS 5.5
Posted by Alvin Lowery on November 23, 2012 at 2:30 pmCan you import and edit Avid DNX Files in Premiere CS 5.5?
Ryan Holmes replied 13 years, 7 months ago 4 Members · 4 Replies -
Angelo Lorenzo
November 23, 2012 at 7:46 pmNatively, no. Avid does have a Quicktime codec for DNxHD available here https://avid.force.com/pkb/articles/en_US/Download/en392959
You’ll need to rewrap your MXF files to Quicktime to avoid reencoding them. I would imagine that Avid has a command for this (Avid is a decent sized hole in my knowledge). FFMPEG and FFMBC can rewrap video, but freak out over AAF audio.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
Ryan Holmes
November 24, 2012 at 10:18 pmYou cannot import DNxHD MXF files natively, as Angelo states.
You can import DNxHD mov files after you install the free codecs from Avid. I believe Avid Quicktime Codecs LE 2.3.7 is the latest from Avid: https://avid.force.com/pkb/articles/en_US/Download/en423319
You’ll need to re-wrap the MXF files to mov for Premiere to ingest them.
Ryan Holmes
http://www.ryanholmes.me
vimeo.com/ryanholmes -
Tom Hoopengardner
January 30, 2013 at 3:52 amI’m using Premiere CS5 with Windows Vista. I need to edit DNXHD files. I can’t import them directly into Premiere CS5, so I try downloading the Avid codecs. Then what? Still can’t import the files. What does it mean to rewrap them? I need idiot-proof guidance.
TomHoop
Ryan Holmes
January 30, 2013 at 8:52 pmTom you probably ought to start a new thread for your question. This a 2 month old thread that you’re posting to.
Per your question the Avid MXF files have to be transcoded to a Quicktime Movie file and then brought into Premiere Pro. The Quicktime Movie file can use whatever codec you want – DNxHD, ProRes, Uncompressed, etc. Premiere Pro handles most codecs without much issue. To transcode the footage I think Adobe Media Encoder will handle it (don’t quote me on that though).
Ryan Holmes
