Avid / DaVinci roundtrip problem
Dear all,
I have a problem with the Avid / DaVinci Roundtrip workflow.
I exported my avid sequence as an AAF, imported in in DaVinci and wanted to start grading.
The problem is, DaVinci Resovle automatically groups all the shots I used that come from the same source clip. I mean I have one long master shot, which I used several times in the sequence – and DaVinci wants to apply the same correction automatically to all of them.
You can see it in the timeline if several shots come from the same source clip: there’s a little red sign above the image.
I would like to grade every shot from the film seperatly, even if it comes from the same source clip.
So is there a way to unlink those?Thanks a lot for your help!
C. Lorenz
