Activity Forums Avid Media Composer Avid creates Custom Project?
  • Avid creates Custom Project?
    Posted by Adriana Câmara on February 27, 2012 at 5:15 pm
    Hi!
    I have to create a project for a video with the following aspects:
    1920×817
    Square Pixels
    23,98
    Codec H264
    Audio 48KHz 16bit
    Final Cut let’s me create a project the matches those aspects. But I didn’t find a way for Avid to do this. If I create a 1920×1080 video size project, my video of 1920×817 gets distorted. Do you happen to know how can I create a custom project in Avid so that it fits the aspects of my video?
    Best regards!!!
    Adriana Camara
    Adriana Câmara replied 14 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    February 27, 2012 at 5:52 pm
    You can’t create custom project settings in Avid MC. Avid is designed to work with standard film and video formats. What you have isn’t standard. 1920×1080 is standard.
    Where did you get 1920×817? Very odd format.
    Shane
    Little Frog Post
  • Adriana Câmara
    February 27, 2012 at 5:57 pm
    Hi, Shane,
    Thank you very much for your answer.
    It’s a short movie that was recorded in a Canon 5d with the aspec ratio 1920×1080. Then, it was edited in Final Cut to be screened in the movies with the aspec ratio 2.35:1 (cinemascope), which is 1920×817.
  • Ricky Barrow
    February 27, 2012 at 7:47 pm
    Is this something you can edit in Avid and run through AE? Or even edit in AE?
    Ricky
  • Adriana Câmara
    February 27, 2012 at 8:05 pm
    I need to add subtitles. I’ve never used After Effects. I guess can try. 🙂
  • Job Ter burg
    February 28, 2012 at 3:44 pm
    You can import 1920×817 into Avid. Tell it to “Do not resize smaller images” in the import settings. Then it will be letterboxed within 1920×1080.
    If you’re doing AMA rather than traditional import, choose Bin->Choose Columns, and display the Reformat column, then click it to select “Pillarbox/Letterbox” (rather than the default setting which is Stretch).
  • Adriana Câmara
    February 28, 2012 at 4:42 pm
    Hi, Job,
    Letterbox is not very good for me because it creates a back area above and bellow the video and, so, when the video is projeted in the movie screen, the black area will be projected to.
    Is there any other way?
    Best regards,
    Adriana.
  • Job Ter burg
    February 28, 2012 at 7:00 pm
    Aside from the fact that theatres are masked for that, so it should not be too much of a problem, you can still perform whatever you need to do in MC, then export, then crop back to 817.
    You simply cannot work in any non-broadcast canvas size in MC.
  • Adriana Câmara
    February 28, 2012 at 7:10 pm
    Ah, ok.
    But do you happen to know how could I crop the video for 817?
  • Job Ter burg
    February 28, 2012 at 7:28 pm
    Export a QT Ref, then in QT Pro, export, and set the size to 1920×817, choose Preserve Aspect Ratio, and choose Crop.
  • Adriana Câmara
    February 28, 2012 at 7:58 pm
    Oh, great!
    Thank you very much!
