Activity Forums Avid Media Composer Avid crashes with G-Raid drive
  • Avid crashes with G-Raid drive
    Posted by Rob Roams on May 23, 2011 at 1:07 pm
    I posted this in the G-Tech forum. Thought I would give it a try here as well. Thank you.
    I have been using my 2gb G-Raid on my PC and editing with Avid Media Composer 4 for about a year. I have MacDrive 8 installed and the drive as been working great. Today I hooked my G-Raid drive up to my Mac book Pro. Did not use Avid software. Then hooked the G-Raid back up via FW800 to my PC. The drive works and I can see all my files on the drive. However, when I launch Avid, it starts to initialize then right before the project window pops up, Avid closes. When I have the drive off, Avid launches fine. Once I turn the G-Raid on, Avid closes out. Can somebody let me know how this can be fixed.
    Rob Roams replied 15 years, 3 months ago 2 Members · 5 Replies
  • Dan Marlow
    May 23, 2011 at 1:28 pm
    First off. Try plugging it into a mac and using the disk utility to “repair disk”. If you have disk warrior, even better – use that to do a rebuild.
    If this doesn’t work, try making a fresh Avid MediaFiles folder structure and allow avid to rescan it.
  • Rob Roams
    May 23, 2011 at 5:34 pm
    Thanks Dan. I will give that a try.
    All I would like to do is export a sequence from Avid Xpress dv 3.5.3 I tried QT, Mpeg 2 and DV. The output quality is very poor. What do i need to do to output a high quality sequence? Thank you
  • Rob Roams
    May 24, 2011 at 12:19 am
    Thanks Dan. The repair disk worked!
  • Dan Marlow
    May 25, 2011 at 7:46 am
    You’re welcome. re: exporting.i would recomend exporting a Same as source QT or QT reference and then compress in mpeg streamclip or similar.
  • Rob Roams
    May 25, 2011 at 1:03 pm
    Some way that question ended up in my message signature. Thanks!
