Activity Forums Avid Media Composer AVID CPU slowdown
  • AVID CPU slowdown
    Posted by Ron Dylewski on January 7, 2010 at 5:29 pm
    Hi –
    I’m running an HP xw8600 with Avid v2.8.3
    Over the past couple of weeks it has started to slow down
    considerably. This is seen in slow renders, slow opening and
    closing of the app itself, slow auto saves, etc…
    There is more than enough space on my media RAID and the C drive
    is fine as well. No new software has been loaded.
    Any ideas?
    Thanks.
    Ron
    Job Ter burg replied 16 years, 8 months ago 3 Members · 3 Replies
  • Michael Hancock
    January 7, 2010 at 5:53 pm
    Possible OS updates? Windows defaults, I believe, to having automatic updates turned on, as does Quicktime. Check both to see that those are turned off.
    Also, do a fresh boot of the computer then pull up your Task Manager to see what’s running. If anything looks out of the ordinary, kill it and see if your system speeds up.
    Is the system overall running slow, or just Avid? If it’s just Avid, back up your projects and reinstall. It doesn’t take more than 20 minutes or so. Try making new user settings too. Yours may have been corrupted.
    Michael
    I’ll be working late.
  • Ron Dylewski
    January 7, 2010 at 5:58 pm
    Michael –
    I’m on a corporate network, so no OS updates get made to this system
    unless I know about it.
    I’ll take a look at the Task Manager. Maybe something is running in the BG…
    Only Avid seems to be pokey. I’m actually due for an update to v4.0, so I probably won’t do a reinstall in the meantime.
    Many thanks!
    Ron
  • Job Ter burg
    January 9, 2010 at 7:57 pm
    Prepare for some major speed and functionality improvements when going from 2.8 to 4.x!
