Activity Forums Avid Media Composer Avid Composer Window Won’t Stay Put when using Option+Control
  • Avid Composer Window Won’t Stay Put when using Option+Control
    Posted by Justin Cordes on October 26, 2011 at 8:06 pm
    I use the Command (apple) + Option key a lot to snap to edits, but, when I do, on this particular Avid, the Source/Record window OR Composer window changes from the Source/Record to just Record. If it click it again it goes back to normal (the Source & Record both appear).
    This is Media Composer 5.0.4.1 on a Mac (2X3 Quad Core Intel Xeon).
    Any idea how to stop this from happening?
    -Justin
    Kenton Vannatten replied 14 years, 10 months ago 3 Members · 2 Replies
  • Deleted User
    October 31, 2011 at 4:53 pm
    I have so many shortcuts floating around my head from 4 different NLE packages that I use so I could be wrong, but isn’t the snap function in Avid just holding the command key while dragging?
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Avid Artist Transport • Media Composer 5.5 • Final Cut Studio 3 • Premiere Pro CS5
    • Living my life one frame at a time •
  • Kenton Vannatten
    November 2, 2011 at 7:24 pm
    In order to snap tails you need to hold Option.
    the behavior described is a bug. It happens if you just hold option and click your tc track. I can’t recall if it’s been fixed in v5.5.3 or not
    Kenton VanNatten
    Avid Editor (for hire)
