Activity Forums Avid Media Composer avid composer project to avid express pro
  • Michael Hancock
    July 8, 2006 at 1:21 am
    Yes. They are .omf files just like Media Composer 2.1, 1.8, the old Meridien systems, Xpress DV… The only thing you need to check is that you’re using a resolution that Xpress Pro will play–1:1 with Mojo, DV50 (or something like that) and DV25-411, if I remember right. If you’re using a resolution in Media Composer that isn’t supported on Xpress Pro, just transcode before you transfer the media.
    Mike.
  • Mhg144
    July 8, 2006 at 6:11 pm
    thanx
