Activity › Forums › Apple Final Cut Pro Legacy › Avid Codecs and FCP
  • Avid Codecs and FCP
    Posted by Subspecies on January 18, 2007 at 7:19 pm
    ok,
    i might be going crazy here….but last night i downloaded from Avid, codecs for output (you know, for output from Quicktime or AE).
    I installed them and evertyhing looked normal.
    This morning, i go to open up FCP and it immediately crashes on start up…i’ve done nothing nor installed anything since the last time i worked on FCP apart from the AVID codecs…
    could it be the Avid codecs that have caused this startup crash with FCP?
    if so, how do i uninstall them?
    if not, anyone else have any suggestions? i’ve got the latest verion of FCP if that helps..
    please help….
    John Pale replied 19 years, 8 months ago 5 Members · 8 Replies
  • 8 Replies
  • Wes Plate
    January 18, 2007 at 10:38 pm
    Read this article… https://docs.info.apple.com/article.html?artnum=304477
    To remove a codec you remove it from “/Library/QuickTime”
    — Wes Plate
    Automatic Duck
  • John Pale
    January 19, 2007 at 12:24 am
    The Avid Codecs and a few other third party codecs (Media 100, also) cause this problem. Just do as Wes says, and remove them from Library/Quicktime.
    This only affects FCP, so you can temporarily install the codec to use with Compressor. Just convert your Avid files to something else using Compressor, then remove the Avid codecs.
  • Tom Matthies
    January 19, 2007 at 2:19 pm
    Hmmm…
    I currently have the Avid Merdien codec installed and it seems to behave just fine.
    Is it only certain Avid codecs that can cause problems?
    tom
  • John Pale
    January 19, 2007 at 2:53 pm
    [Tom Matthies] “Hmmm…
    tom
    This is not the Meridien Codec. This is the latest Avid Codec (dated Sept.27 2006) on Avid’s site, and available here.
    https://www.avid.com/onlineSupport/browse.asp?productID=0&topicID=404&browse=
    The new Avid codec supports many more resolutions, including the DNxHD codec and the Avid DV resolutions.
    I have not tried the older Meridien Codecs. I will try them again. In the past, they would not prevent FCP from launching, but they did have erratic behavior, and false “out of memory” errors.
  • John Pale
    January 19, 2007 at 2:58 pm
    Just installed the older Meridien Codecs. FCP launches just fine.
    It’s only the new Avid Codecs that cause the problem.
  • John Pale
    January 19, 2007 at 3:36 pm
    The latest Avid codecs Version LE 1.20 install 5 components into Library/Quicktime
    Remove the following components:
    AvidAVdvCodec.component
    AvidAVpkCodec.component
    FCP will now launch normally.
    AvidAVdvCodec.component is the Avid DV Codec, which probably conflicts with the Apple DVCodec, which FCP uses.
    Not sure what AvidAVpkCodec.component is for. I am able to import all Meridien resolutions and DNxHD resolutions
  • Ben Kalb
    January 19, 2007 at 8:40 pm
    Where do you get the older Meridian Codecs? I would like to install them on my FCP system. I have two Avid Meridian systems up and running (PC version) at my office. It would be nice if I could swap files without dumping to tape.
  • John Pale
    January 19, 2007 at 9:02 pm
    All Avid codecs, new and old are on this download page.
